Hi I'm wondering if anyone has experienced this problem or has a solution to it which costs less than the OEM parts.
Pictured here is two fan blower motors for a zero clearance fireplace. These motors sit in the lower portion of the fireplace and circulate room air into and around the heat box then to the ducting above the unit to warm air ducts connected to it. There is no hot air being passed through these motors but the area around them can get warm but not exactly really hot.
These motors are beginning to fail due to age mostly the specs are 115VAC, 50/60Hz, 24/22W, Impedance protected Class B Insulated. The outside dimensions are 4 5/8" X 4 5/8" with a 5 blade fan and a diameter of 4 1/4" .
The OEM parts costs $300.00, so I'm quite sure there's something that will be suitable for much less than than that out there I just have to find it.
If anyone has information that will help it would be greatly appreciated.
Thanks![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Ron
Ron
