BU2527AF Transistor Replacement
Gautam99
Hello,
I am new in this forum . I want to replace HOT (Horizontal Output Transistor) transistor BU2527AF with a new one which number is NTE2365 . I do not know too much about electoronics . I finding a mismatch between two transistor -
BU2527AF has VCESM ( Collector-emitter voltage peak value ) - 1500V
But NTE2365 has VCBO ( Collector to Base Voltage ) - 1500V
Here is mine Problem . NTE2365 has no VCESM value . It has VCBO 1500V instead of VCESM .
Now I want to know - are this VCBO and VCESM same or Different ?? Can I use this HOT transistor as a replacement of BU2527AF ??
Thanks .... I am waiting for your quick reply .........
I am attaching the Datasheet of NTE2365 and BU2527AF below for your consideration .......
  • BU2527AF.pdf
  • NTE2365.pdf
