Buck supercap charger...LT8391
Flyback
We have to do a supercap charger. It just has to keep a 25F supercap charged up to 6V. We choose 20A charge current. The supercap will be getting discharged every 15 seconds or so.
Vin = 37V
The attached LT8391 sim in LTspice does the job….its set for 150khz, but when the supercap is near zero volts, the LT8391 sim conveniently reduces the switching frequency so the on_time is more realistic. We wonder if the actual real LT8391 chip will do this?..because the datasheet doesn’t say it will.
Also, the LT8391 is a 4 switch buckboost controller…however, since we only ever wish to use it in Buck mode, we will only fit the two sync Buck FETs…do you think this is OK?…it certainly works in the sim…datasheet doesn’t say though.
Also, concerning the LSP_LSN current sense resistor, it is in the (noisy) switching node of the Buck…..but since we are not using buckboost mode, is it now ok for us to move the LSP_LSN sense resistor to just downstream of the buck inductor, so that it is now no longer in the noisy switching node?...once again, this certainly works in the LTspice sim, but will it work in the real hardware?
LT8391
  • LT8391_ISEN.asc
Unless anyone here has built such a charger using that same IC in exactly the way you want to (unlikely) we would have to guess. Can't you build a prototype to see how the IC behaves in practice?
Examining the interface signals tells me the current soft start uses PFM, by design, thus frequency of pulse controlled average current. This is controlled by the Vref filter. I would have thought this was obvious.
"is it now ok for us to move the LSP_LSN sense resistor to just downstream of the buck inductor," ?? as is?
Thanks, if you see the schem on datasheet page 1.....we only use this thing in Buck.....so we can have the LSP_LSN sense resistor NOT in the buck switchign node?...(ie put it the other side of the inductor...the output side?
I appreciate there is soft start...but these supercaps are 25F.....so ayk, the soft start will time out when the vout is still very very low.
