Buffer too small error
electroRF
I wrote the following C++ constructor, and I get an error - BUFFER too small on strcpy_s
Trace::Trace(const char *str)
    if (str)
        int len = strlen(str);
        this->m_name = new char[len+1]; // asking for 'len+1' memory elements of char
        strcpy_s(m_name, len, str); // **** I get here an error "BUFFER TOO SMALL" ****
        cout << "start of " << m_name << endl;
    else
        m_name = new char[1];
        m_name[0] = '\0';
m_name is a private data member of type char* .
You have an idea why I get this error?
Hi Ian,
Please see my answers to your questions:
How big is is the buffer m-name? It seems as if its smaller than len!!
m_name is:
char *m_name;
is is a pointer and i dynamically allocated 'len+1' char elements to it.
strcpy is for ( dest, suorce)
strncpy is for ... ( dest, source, len)
I used strcpy_s which receives (dest, len, source)
Hi Ian,
Please look at the code i posted in the first post.
I did initialize the pointer m_name:
tried it out before, i don't remember exactly what error it generated, but there as an error still..
The following worked instead:
memcpy(m_name, str, len+1)
But I still don't get it, why strcpy_s did not work?
It will work ("The destination string must be large enough to hold the source string, including the terminating null character.") but strcpy_s is non-standard and MS specific. Memcpy will work with PODs in C++.
https://en.wikipedia.org/wiki/Plain_old_data_structure
If you read the description of strcpy_s(), you'll see that the second argument the size of the buffer. By passing len you say:
Dear strcpy_s() function, I want to copy the string from src to dst, but my dst is only len bytes long. Make sure not to overrun it.
strcpy_s() tries to copy and finds out that copying would require to put len+1 characters into the dst buffer. So it says:
Dear electroRF, I would be glad to copy for you. I would need len+1 characters, but you told me that only len is available. So, I better return the "Buffer too small" error.
This would work:
C:
strcpy_s(m_name, len+1, str);
However, using memcpy() would be better because you already know the length.
oh got you NorthGuy!
Thank you!!! :)
I thought that the size_t len was the length of the string, as in C string (i.e. excluding the NULL character), and not the size of dst.
Thank you for clearing it up!
