Build circuit police strobes with 2 disposable camera Flashes.
Yes it would be, but not to mimick a police strobe, that would be illegal.
The recovery rate for a camera flash is too long.
There are ways to alter it, however, it decreases the light output. Hack a flash camera into a emergency strobe light demonstrates how.
Altima: The cameras are cheap (often free), so parts cost is not much of a concern. I would do it using two cameras modified as in the link above. Then, use a standard astable multivibrator circuit to switch the power supply between them. This way you work with lower voltages and easily available schematics/parts.
As Sceadwian mentioned, its illegal to impersonate an officer. However, flashing lights have uses outside the law enforcement community. Please use these ideas in a responsible way.
You can always just increase the voltage, and pray the circuit hold together, and it will for a short period of time. You can also just copy the camera flash circuit and increaes the size of the transformer and transistors. The transformer is the weak link I believe.
You certainly cannot increase the voltage. It is designed for 1.5 and takes up to 700mA. You cannot change anything. I have already put hundreds of old "guts" into strobes and made them blink automatically.
Here is the circuit:
You certainly can if the voltage is well controlled for short burst durations of pulses. I have done so successfully, this is for short term use of course. As discussed already if what the OP wants is a long term solution to driving flash bulbs especially for a needed safety vehicle application, using a camera flash circuit is NOT the answer.
Sceadwian You certainly know what you are doing. I am only an idiot that produced over 100 with auto flash and tried to use 3v and overheated the transistor. The transformer was saturated. But you know better. I am only a fool.
Rather absolute... no exceptions?
I built a heavily overpowered flash in 1984 from camera flash components. It never worked? It sure looked to me like it worked. It still looks like it works....
A camera flash cannot operate as a strobe with the same capacitor and voltage for long. The glass tube itself will overheat and crack from the flash pulses.
You MIGHT think you'd just use a smaller flash capacitor, thus limiting the energy of each flash. This will work, bu the strobe's efficiency (and color temp) degrades quite a bit if you reduce the flash power, making it a somewhat poor design. A lot of cheap strobes DO work like this, and appear to use flashtubes similar to cameras. They may BE surplus camera tubes, I don't know. Perhaps this is what happens to all those "disposable cameras" after they're shipped off to be developed.
I built my flasher for a theatrical effect and hoped it would work for maybe a week or two. Imagine my surprise 25 years later...
The tubes (3 of them) are 25mm long and about 2mm in diameter. I charge 150uF to about 350V, and fire each tube about once per second (the assembly flashes 3 per second). They get hot in a hurry but I don't leave them on for very long.
I made a strobe light once. I held a flashlight in one hand and waved my other hand in front of the light real fast... :)
Of course it's possible to power a strobe to work from other voltages, I've seem many strobes working from 12V.
In the case of a disposable camera, you just need to rewind the primary for higher voltages or simpler still, reduce the duty cycle of the primary waveform.
I am only a fool.
You said it.:p
Just use LEDs.
Here's a circuit I came up with using a quad Schmitt trigger NAND gate.
U1A is a high frequency oscillator and U1B is a low frequency oscillator. I've not calculated the frequencies so you might need to change the resistor and capacitor values to slow/speed it up, depending on your preference.
I have another idea which will work with four CMOS inverters, so will work with a quad NAND, NOR or a hex inverter IC, if you're interested.
suppose you could have 10 chargers, and 10 capacitors, and ''open'' each capacitor to the same bulb with a decade counter, hopefully by the time the 10th capacitor is discharged, the first one is charged again
Sounds like a crazy idea, I can't see it working.
No colin you're not a fool, but I have done this before, and I never said doubling the voltage was safe, increased voltage WILL increase the flash rate of the stock circuits normal ability, I never quantified it, and as I explicitly stated will shorten the life of the circuit if it's done for anything but brief periods of time.
Nigel, what is the difference between a flash/strobe tube? The gas is the same isn't it? Is it just volume/concentration?
1) The one tube will get hot. Give it time to cool while you're charging. Use one tube per capacitor.
2) A typical decade counter does not have the capability to carry the flash current.
3) You can design a circuit that "hopefully" will work. Or you can do the math.
