stormrazer121
So after trolling through this forum looking for information and doing research after research on parts and ICs and how it all works, and finally making my own little circuit i feel pretty confident enough to make a 2.1 amp to incorporate a sub into my next project
But something i do not understand is how i would do this, i have a number of ICs hangin about, one which just happens to do just that is from a board i pulled apart, its part number is,
4558d jrc sum 6b29w, there is 2 other ICs on the circuit but im sure this is the one for the amp,
However i understand how to make a normal mono amp and how to use two to make a stereo setup but something i do not understand is how i would convert one to drive a small driver as a "sub" only small but i only need small as it is a tiny setup with 2" 4 omh 2watt speakers, Hench the need for a sub as there is no bass at all.
So does anyone any advice on what i could do to make only low frequency be sent to the sub? thanks
P.S - i learn t how to read diagrams so if you have one i can look at i should be able to read it and work out what i need to do thanks guys
