They also don't take it very well when disscharged lol!just a tip. it is good if you cand find a lead acid battery. they take it very well when overcharged
Not nescessarily better, just much cheaper and easier to maintain. You could even use normal batteries. Using a flourescent lamp will increase efficiency and therefore would mean a high capacity battery is not as necessary.so you say that NiCd batteries are better?
Ooops???... NiMH are the ones that 'Don't' suffer from memory effect That nasty is reserved for NiCads. Lion's require somewhat more complex charging circuitry. Stick to NiMH'sMcGuinn said:NiCd are phased out due to the existance of posionious Cadnium within them. NiMH suffer from memory problems, so that leaves Lion... they are good.
