EvilGenius
Hello
Here is another clever circuit that will create cool effects for a large array of smart pixels.
Objective:
Low cost circuitry
Easy to built and implement
No fancy bitbanging and worrying about timing constrains
Utilize any WS2811 based controller for RGB Lighting (Single Wire SPI)
Be able to continue to daisy chain different string lenghts without addditional programming
Avoid messing with re-programming WS controller, avoid bit counting or system slowing down
Create cool Fx on 15 strings of 50 nodes (horizontally and vertically)
Avoid zig-zag connection end to end (save on wiring)
Be stand-alone (no need for a fancy computer software)
Run on 5V or 12V 3-wire system
Circuitry:
The heart of the system is four 4-Bit 3-State Avtice High Non-Inveting Buffers allowing multiplexing of a Microcontroller with Data output from WS2811 Controller. Buffer has individual Enable lines connected to Microcontroller, while all the data inputs of the buffers are tied together and connected to WS2811 Controller Data output. uC controls individual isolated horizontal lines while WS-CNT provides for vertical movement and color FX. Output of the buffers are connected to 15 strings of 50 smart pixels (750 nodes).
BOM:
4 x 4-Bit CMOS Buffers Active High Non-Inverting (SN74AHC126N) $1.20
1 x Microcontroller (PIC16F628A) $1.20
1 x WS2811 SPI Controller with Remote $6.50
6 x 0.1 uF Ceramic Decoupling Capacitors $0.12
1 x 220uF Electrolytic Capacitor $0.05
1 x 5V Voltage Regulator $0.66
1 x Resistor 51 Ohms $0.02
2 x Resistor 4.7K (Pull-up) $0.04
16 x Resistor 100 Ohm $0.32
Total cost not including PCB: $10
Circuit should be able to create amazing FX by varying the sequence of which string(s) comes on (PIC output) at what time and duration, pause, slow down, speed up, rotate, do Bullet time, Matrix Rain FX, Slow-Mo FX, Sprial FX, Random FX, Move Action while doing spiral, freeze vertical and do horizontal or circular movement, Freeze horizontal and move all colors synchronized up or down, and much more.
Objective:
Low cost circuitry
Circuitry:
BOM:
