Butler Bot
I have an Idea for a butler bot. It will carry around, well, almost anything that fits in the box. It will have two levels. the top level will be a 15.5 x 12 black rectangle with a metal frame around he bottom for support. the box will sit in a hole cut out of the rectangle. this sits on 4 15" aluminum tubes hooked up to the lower level. It has all of the boards, chips, batteries, and wheels. the wheels will go through the lower level holes and will be controlled by a gear box.
I already have allot done, but still need to know what gearbox and wheels to use and what is a light weight wood to use for the walls. I was thinking of using this and **broken link removed**. the robot weighs like 7.5 lbs now, i think, would it have high enough torque? do you guys think it could go 1 ft/2 sec.
Thanks![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
