C++ and Serial Ports ?
Eng_Bandar
Hi all,
This is first post for me in this forum and I need your helping.
I am very wonderful from C++,I thought I will find more tutorials about C++ with serial communication but after search I didn't find good tutorial about this case Why? C++ very famous and very strong. I am very frustrate from this. I don't want begin wiht new programming language (C#, Java, ...etc). Most codes in web about this case contain errors.
I use Microsoft Visual C++ 2010.
Any simple tutorials, Any advices, Any simple codes (like send 'a' through serial port).
You could give C# a chance.
This is serial port code in C#:
SerialPort serialPort1;
serialPort1 = new System.IO.Ports.SerialPort();
serialPort1.BaudRate = 9600;
serialPort1.PortName = "COM1";
serialPort1.Open();
serialPort1.Write('a');
This is serial port code in C (small part of it):
/** Initialize the serial port for data transfer with ATmega88.*/
int com2_initialize(void){
  int fd;
  // Initialize the serial device
  fd = open(COM2_DEVICE, O_RDWR | O_NOCTTY);
  // Returns error if failed to initialize the device.
  if(fd < 0){
    writelog("rs232laser", "failed to initialize serial device, fd was %i", fd);
    return 0;
  // Get and save the current serial port settings.
  tcgetattr(fd, &presentTermIO);
  // Initialize structure for new port settings.
  memset(&newTermIO, 0, sizeof(newTermIO));
    Set necessary attributes for port.
    Attributes:
    BAUDRATE = bps rate
    CS8 = 8bit, no parity, 1 stopbit
    CLOCAL = local connection, no modem
    CREAD = enable port for receiving characters
  newTermIO.c_cflag = COM2_BAUDRATE | CS8 | CLOCAL | CREAD;
  // Enable raw output.
  newTermIO.c_oflag = 0;
  // Set input mode to non-canonical.
  newTermIO.c_lflag = 0;
  // Non-canonical input processing parameters.
  newTermIO.c_cc[VMIN] = COM2_MAX_INPUTSIZE;
  newTermIO.c_cc[VTIME] = COM2_TIMEOUT;
  // Clean the modem line and activate the settings for the port.
  tcflush(fd, TCIFLUSH);
  tcsetattr(fd, TCSANOW, &newTermIO);
  return fd;
serialPort1.Open();
  int fd;
  if(fd < 0){
    return 0;
    Attributes:
    BAUDRATE = bps rate
  return fd;
Thank you so much
I killed the frustrating by C#
Thanks again
this is first project for me in C#
YouTube - EngBandar1's Channel
