C Block Compact Code
Suraj143
Active Member
I want to declare 192 GPR in C block.Is there any easy way of doing it without writing all 192 bytes in C block? I use PIC16F88
Will this work?
cblock 110h
Byte:60h ;96 bytes
endc
cblock 190h
Byte:60h ;Next 96 bytes
endc
That should work but the areas will have a gap between them. How do you intend to access this 192 byte block?
Will this work?
cblock 110h
Byte:60h ;96 bytes
endc
cblock 190h
endc
You can use the decimal numeral as well (hex not required). Just make sure all of the registers are available before making an assignment. That is, make sure they are not reserved as special function registers.
