C, neat way to convert ascii float to int
dr pepper
Most Helpful Member
I'm receiving a percentage from a machine controller over rs232, it insists on sending me a percentage to 9 decimal places.
I only want a percentage integer no decimal.
I'm trying to think of a neat way to convert 10.000000001% to 10%.
Can't you just use just perform a digit by digit ASCII to int conversion (accounting for weighting of each digit using a case statement to associate each ASCII digit with a numerical value) and stop when the decimal is encountered (or start at the decimel point, depending on which direction you want to move through the digits)?
Basically, pretend you're actually converting an ASCII int into to an int but use the decimal as the termination character instead of the typical null character.
Can't you just use atoi(); ?
That will convert the string to an int, only using the digits prior to the decimal point.
atoi() generates an error, I think its the decimal point that messes it up.
Rounding would be nice.
I think I'll try indexOf() and pull the figures out into a buffer, it does seem 'unclean'.
atof() is the one you need, but it's a crass way of doing it, You would be better of writing a small routine that runs through the ascii number until a decimal place or a CR is reached.... Doing it this way will allow you to look at the first decimal digit and round it yourself..
There is a cool function in the string library that will check a string for the first occurrence of '.' and the result is the place in the string.. Then you can add the figures as you can determine the decimal weights beforehand.. strcmp() will accept the delimeter of your choice and return its position..
Try this, https://onlinegdb.com/SJyDRrYzN
If that doesn't work,
int ptoi(char *percent){
    char i=0;
    int num=0;
    while(percent[i]>='0'&&percent[i]<='9')
        num=num*10+percent[i++]-0x30;
    if(percent[i]=='.'){
        if(percent[i+1]>='5'&&percent[i+1]<='9')
            num++;
    return(num);
int main()
    printf("Percent 23.123 = %i\n",ptoi("23.123"));
    printf("Percent 23.567 = %i\n",ptoi("23.567"));
    return 0;
Or, if atoi is complaining about the decimal point?
C:
char *p;
p = strchr(string, '.');
if(p) {
    *p = /0;
i = atoi(string);
the classic method for rounding a floating point number to integer is simply to add 0.5 to the float value and then truncate it to integer. No need to mess around with 'If" constructs.
However, it's a string not a float.
I'm not especially familiar with this version of C, but I assumed (yes I know, dangerous to assume) that you can convert a string to a float, add 0.5 and then truncate to integer.
You can go via a float but introducing floats will add a huge chunk of code. The code above will be much smaller and quicker.
    char i=0;
    int num=0;
            num++;
    return(num);
int main()
    return 0;
This is a nice solution. Nice one Mike
Gonna test run #8 and see if that works, seems ok code wise, might compile to a lot more.
Normally code written specifically for a task is usually smaller and faster than using libraries. The code I posted above has the advantage of rounding and will definitely be more compact and faster than a float method and probably the itoa method as well.
Yup, I find in this forum in particular, sometimes the best solution is often ignored/brushed off for some reason.
Someone will post a solution which is perfectly adequate, but another member will post something arguably worse afterwards and that will take the thread/OP on a completely unnecessary tangent.
I guess that's why different platforms (stackoverflow/reddit) have a rating system.
