C Programming. Problem searching for name stored in variable
spitso
Hi all
Just trying to search for a variable (case in-sensitive) and then display the variable that matches, but cant quite get it too work.
attached is my code.
tested with a .txt file and searched for an exact match but nothing displayed
any ideas?
1. Are you sure you want to pre-increment your index "p" (++p)? Probably should be p++ instead.
2. You misspelled "field". That's why it doesn't work. (Jes' kidding!)
3. Horrible colors. I can't see the comments in blue at all.
So you don't have a strcmpi() (case-insensitive) function in your library? Would save you the trouble of going through strings and tolower()-ing them.
searchField is a char and you're assigning the title to it
tolower takes a char and not a char*
also returns a char and not char*
even if you passed char into tolower, it would not change the character to a lower case. You'd have to do someting funky like this
string[X]=tolower(string[x])
But you sholdn't need to convert the case for a case-insensitive search anyway. There are better methods.
PS: On second thought, strcmpi() might not be an ANSI C function, so conversion might be necessary.
searchFeild should really be declared as
char searchFeild[100];
as it's a string (char array), not a single character.
Converting searchFeild to lowercase must be done on all characters in the string, thus
for(p = searchFeild; *p; p++)
*p = tolower(*p);
