I have today converted a project from BoostC to C18 and had a rather nasty bug. I finally tracked it down to one bit of code that wasn't working correctly. Here is that code in isolation,
What this code should do is find the first non zero bit in temp and so count should contain 11 after it executes. Well, it doesn't, it contains 7. C18 works with bytes when it does 1<<count. What is even more peculiar is that temp=1<<11 will place zero in temp not 0x0800 as you would expect.
You can fix the above by doing while((temp&((int)1<<count))==0) or adding -Oi command line option.
So, why am I telling you this. Cause it took me a long time to find it and I just had to get it of my chest. Plus, it may help others.
BTW, the above worked fine in BoostC and it is the C18 compiler that doesn't comply with ISO.
Edit, One good point about C18 is that it's free.
#include <p18f1320.h>
#pragma config WDT = OFF, LVP = OFF, OSC = INTIO2
void main(){
char count;
unsigned int temp;
OSCCON=0x60; //Osc=4MHz
ADCON1=0x7f; //All digital
count=0;
temp=0b0000100000000000;
while((temp&(1<<count))==0){
count++;
while(1);
