On the below circuit the feedback resister value must be 9K.But with 9K I get those errors.
Op amp output disconnected from PIC ADC
@ 30’C, PT100=111.6 Ohms, op amp output shows 0.515V.
Op amp output connected to the PIC
@ 30’C, PT100=111.6 Ohms, op amp output shows 0.44V.
There is a 4’C difference. So the temperature shows 26’C instead of 30’C.
I changed four CA3140 op amps from different manufactures & all shows different outputs.
The problem solves when I adjust the gain until I get the correct values. But then again when I disconnected the Op amp output from PIC ADC the op amp output value will be too higher.
Why is this happening? How to solve this?
