mersenne31
I have some questions about the pros and cons about two different methods used for calculating the volume of fluid used from a container.
One idea is using a flow meter to calculate the flow rate of fluid leaving the tank; the other idea is using a load cell to calculate the weight of the container before and after the fluid has been discharged.
Which one would be more accurate? Which one would be more complex to implement?
