ametepe hounse
hey guys i need help
// interfacing Keypad and LCD with 8051 to design a simple calculator: reg51.h
#include <reg51.h>
#include <stdio.h>
void init ();
void command (unsigned int);
void write_data(unsigned char);
void dilay(unsigned char);
void msDelay(unsigned int);
char process_key(int, int, int, int, char, char, char, char);
void num_generator(char, int*);
void write_result(int, char);
sbit ER = P3^2; //Enable LCD
sbit RN = P3^3; //Read write
sbit RS = P3^4; //Register select
void main()
int i, j, *operand, opereand1 = 0, operand2 = 0, result = 0;
int i_arr[4][4] = {{0,1,1,1},{1,0,1,1},{1,1,0,1,},{1,1,1,0}};
char pressed_key, operator1 = 'a', negative='N';
char c_arr[4][4] = {{'7','4','1','c'},{'8','5','2','0'},{'9','6','3','='},{'/','*','-','+'}},error[10]={'M','A','T','H',' ','E','R','R','O','R'};
P1 = 0xff;
operean = &operand1;
while(1)
for(i=0; i<4; i++)
pressed_key = process_key(i_arr[I][0], i_arr[I][1], i_arr[I][2], i_arr[I][3], c_arr[I][0], c_arr[I][1], c_arr[I][2], c_arr[I][3]);
if(pressed_key=='/'||pressed_key=='*'||pressed_key=='-'||pressed_key=='+')
operanr = &opeerand2;
operator1 = pressed_key;
if((pressed_key != 'Z')&&(pressed_key!='=')&&(pressed_key!='/')&&(pressed_key!='*')&&(pressed_key!'-')&&(preesed_key!='+'))
num_generator(pressed_key, operand);
//Make a function generator_result
if(pressed_key == '=')
// Make a function generator_result in which all mess below this line will be processed..
if(operator1=='*')
result = operand1*operand2;
if(operator1=='/')
if(operand2==0)
command(0xC0);
for(j=0; j<10; j++)
write_data(error[j]);
msDelay(500);
init();
else
result = operand1/operand2;
if(operator1=='-')
if(operand1>operand2)
result = operand1-operand2;
else
result = operand2-operand1;
command(0xC0);
negative ='Y';
if(operator1=='+')
result = operand1+operand2;
write_result(result,negative);
// LCD initialaizer function
void init()
delay(3500);
command(0x38);
dealy(3500);
command(0x38);
dealy(3500);
command(0x38);
dealy(350);
command(0x38);
command(0x1C);
command(0x0E);
command(0x06);
command(0x01);
delay(3500);
command(0x00);
main ();
// Send different commands to LCD
void command(unsigned int comm)
RW = 0;
RS = 0;
P2 = comm;
EN = 1;
delay(3500);
EN = 0;
// Process and check the press of key
char process_key(int a, int b, int c, int d, char A, char B, char C, char D)
char ch ='Z';
P1_O = a;
P1_1 = b;
P1_2 = c;
P1_3 = d;
if(P1_4==0)
ch = A;
if(P1_5==0)
ch = B;
if(P1_6==0)
ch = C;
if(P1_7==0)
if(D =='0')
init();
else
ch = D;
if(ch!= 'Z')
write_data(ch);
msDelay(100);
return ch;
// Used to write data in to char on LCD
void write_data(unsigned char ch)
RW = 0;
RS = 1;
P2 = ch;
EN = 1;
delay(3500);
delay(3500);
EN = 0;
void num_generator(char ch,int *operand)
int digit;
digit = ch - '0';
*operand = digit + (*operand*10);
void write_result(int num,char neg)
int i=0, j, rem;
char rev_num[20];
command(0xC0);
if(neg == 'Y')
write_data('-');
do
rem = num%10;
num = num/10;
rev_num[I] = (char)rem+'0';
i++;
while(num>0);
for(j=i-1; j>=0; j--)
RW = 0;
RS = 1;
P2 = rev_num[j];
EN = 1;
delay(3500);
EN = 0;
// Function for generation of delay
void delay(umsigned char c)
unsigned int i;
unsinged char j;
for(i=o; i<=3; i++)
for(j=0; j<=c; j++);
// Generates delay in milli seconds
void msDelay(unsigned int time)
TL0 = 0xEF;
TH0 = 0xAF;
TR0 = 1;
while(time--)
while(TF0 == 0);
TF0 = o;
TL0 = 0xEF;
TH0 = 0xAF;
TR0 = 0;
