Hello,
is there a way to call a function, sub or something else with arguments by Reference?
Recurrently i have the Problem that i want to read some values from EEPROM to RAM. The Way that I do byte by byte in a Bytearray. The following program uses the values as a Longarray. I can not find a possibility to call a function and pass the value as a Reference of my Bytearray. I need the Long values for my sort algorithm.
Maybe there is as other way to read EPROM Values directly to a LongArray with oshonsoft or pass a value as RAM address of the Variable. Then I can use the implemented Pointer()
My current way is to check the asm code and take from it the ram address of the variables, not nice.
Problem with Oshonsoft for PIC
