Electrolinux
Hi everyone,
I'm designing a laser range finder using the technique of Amplitude Modulated Continuous Wave (AMCW). The range to be mesuared is up to 15 meters. As a photoreceiver, I have the well-known BPW77N phototransistor, but I'm afraid it doesn't have the sentivity enough to detect light from such a long distance. As far as I've read, I'd need an avalanche photodiode (APD) or a built in photodiode-amplifier-filter to do the job. Since these VERY high sensitive components aren't readily available to me (and they are not cheap !!), I wanted someone to advice me before ordering the component.
I don't understand how you can change the frequency of the laser pointer. Mine has a wavelength of 850 nm. Since c = wavelength x frequency and c is a constant, I deduce that the laser diode frequency cannot be changed. However, I know I have to modulate it with a 10 MHz pure sine wave. How is this possible, then ??
Thanks beforehand.
Thanks beforehand.
