i m using PIC16F877..
i want to ask is it for one ANA input, we only have 256 location (because 2^8) to store the converter value of analog input?
can i use EEPROM as external memory in order to store more data converter for one ANA input?
i hv try with Nigel tutorial for EEPROM part, but it seen can't work as well..
i go through Nigel tutorial 6.1
since i m using PICDem2 Plus Demo Board to run the PIC, so i had make some changing in the tutorial source code...
1st part;
I2C_PORT equ PORTC
I2C_TRIS equ TRISC
2nd part;
ErrFlag equ 0x00
StartFlag equ 0x01
One equ 0x02
Zero equ 0x03
3rd part;
#define SDA 4
#define SCL 3
4th part;
Chip_Read equ 0xA1
Chip_Write equ 0xA0
5th part;
org 0x0000
goto Start
org 0x0004
retfie
the 1st and 3rd part i change according to hardware board..
for 2nd and 4th part, i don't know what should i change to..
when i click on Built program, the output show 'Bulit fail because of the 5th part'
1st part;
I2C_PORT equ PORTC
I2C_TRIS equ TRISC
2nd part;
ErrFlag equ 0x00
StartFlag equ 0x01
One equ 0x02
Zero equ 0x03
3rd part;
#define SDA 4
#define SCL 3
4th part;
Chip_Read equ 0xA1
Chip_Write equ 0xA0
5th part;
org 0x0000
goto Start
org 0x0004
retfie
