Sinedup
While working on my microwave recently, a thought popped in my mind.
Will a 2.45GHz 1.5KW Magnetron beam into space?
While it's illegal to broadcast certain RF frequencies without certification, would a standard microwave magnetron, no extra waveguides / dishes etc, pointed directly up, at the zenith, obviously on a raised wooden platform way above heads, transmit any distance?
Normally, running an empty micro oven will destroy the magnetron, if it doesn't have a load (water molecules), as is always warned in manuals.
I've also read on micro-repair websites that the u-wave energy reflections bounce back into the waveguide antenna, which causes the damage.
This is why I'm curious whether 'out in the open' atmosphere 'no-load' would also damage the magnetron?
(Obviously with cooling & HT still in operation, ie a micro oven with 'oven' section cut off.
A radio communications / circuit theory handbook states that the transmission window (through atmospheric layers to space) is from 20m (15 MHz) to 6mm (50 GHz), and the 2450 MHz falls well within this range.
However, the 1500-2000W power-to-distance is unknown.
Any theoretical wizards know the answer(s)?
Just curious..![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Just curious..
