>> Can Anybody Explain This Code For Me? :(
chamith20xx
hi all ... i'm involving with a project of reading data from a SD card using microcontroller. i have came across a coding which i have downloaded from internet and unfortunately the comments in written in that coding is not in English language... :cry: :cry:
so can any one please explain this code for me...Thnx in advance... :wink: :roll:
Please EXPLAIN THIS AS SOON AS POSIBLE IF U ARE ABLE...i have marked the comment mark , " //" where i need explanation.. so feel free to help me... thnx... :)
#include <D:\cc5\16F877.H>
#pragma config |= 0b.11.111101.11.00.10
#pragma bit CS @ PORTC.2 //Ausgang für Chip Select
uns16 AL, BytN,ByteLes,Claster,FAT,Verz,Dat; //
char AH ;
#pragma origin 100
void InitUSART()
BRGH=1;
SPBRG=129; // (9600 baud @ 20MHz input clock)
SPEN = 1; // Set_Serial_Pins;
SYNC = 0; // Set_Async_Mode;
TX9 = 0; // Set_8bit_Tx;
RX9 = 0; // Set_8bit_Rx;
CREN = 1; // Enable_Rx;
TXEN = 1; // Enable_Tx;
RCIE=0; // Rx Interrupt aus
void SerString(const char *str) //
char ps;
ps = *str; //
while(ps>0) //
str++; //
if (ps== 0) break; //
while(!TXIF); //
TXREG =ps ; //
ps = *str; //
char SPI(char d) //
SSPBUF=d;
while (!BF); //
return SSPBUF; //
char Command(char befF,uns16 AdrH,uns16 AdrL,char befH ) //
char a;
for (a=0;a<9;a++)
Carry=0; //
AdrL = rl(AdrL); //
AdrH = rl(AdrH); //
SPI(0xFF); //
SPI(befF); //
SPI(AdrH.high8); //
SPI(AdrH.low8); //
SPI(AdrL.high8); //
SPI(AdrL.low8); //
SPI(befH); //
SPI(0xFF); //
return SPI(0xFF); //
bit MMC_Init()
SMP=0; //
CKE=0; //
CKE=1; //
CKP=1; // CKP=0; //
SSPM0=1;
SSPEN=1; //
CS=1; //
char i; //
for(i=0; i < 10; i++)SPI(0xFF);
CS=0;
if (Command(0x40,0,0,0x95) !=1)goto Fehler ;
st:
if (Command(0x41,0,0,0xFF) !=0) goto st ;
return 1;
Fehler:
return 0;
void Byte_lesen (void)
bit zw;
char a;
int16 i;
zw=0;
Command(0x51,AH,AL,0xFF);
while(SPI(0xFF) != 0xFE); //
for(i=0; i < 512; i++) //
a=SPI(0xFF);
if (zw)
ByteLes.high8=a; //
zw=0;
if (i==BytN) //
ByteLes.low8=a;
zw=1;
SPI(0xFF); //
SPI(0xFF);
void Suche(const char *wort) //
uns16 i,L,N;
bit gef;
char a,m,b;
gef=0;
m=0;
N=Verz+32; //
for (L=Verz;L<N;L++) //
Command(0x51,0,L,0xFF); //
a=SPI(0xFF) ;
b=wort[m];
if(a==b)
m++;
if(!wort[m])
SerString("Gefunden ");
m=0;
BytN=i;
AL=L;
AH=0;
gef=1;
goto fu;
m=0;
fu:
SPI(0xFF); //
SPI(0xFF);
if(gef) goto raus;
raus:
SerString("Beendet ");
BytN+=16;
Byte_lesen();
void Lesen(char H,uns16 L)
uns16 i; //
if (Command(0x51,H,L,0xFF) !=0) SerString("Lese_resp_Fehler");
while(!TXIF); //
TXREG =SPI(0xFF); //
SPI(0xFF); //
SPI(0xFF);
void main(void)
uns16 temp;
INTCON=0; //
ADCON1=0x6; //
TRISC=0b.1101.0011; //
TRISB=0b.0000.0010; //
InitUSART(); //
//SerString("Ich bin ON "); //
MMC_Init(); //
AL=0; // 3
AH=0;
BytN=0x1C6;
Byte_lesen();
AL=ByteLes; // 4
BytN=0xE; // 5
Byte_lesen();
FAT=ByteLes+AL; // 6
BytN=0x16; // 7
Byte_lesen();
ByteLes=ByteLes*2;
Verz=FAT+ByteLes; // 8
Dat=Verz+32; // 9, 10
Suche("TEST TXT"); // 11
while(ByteLes != 0xFFFF)// 12, 25
Claster=ByteLes; // 13
Claster=Claster-2; // 14
AL=Claster; // 15
Carry=0; // 16
AL = rl(AL); //
AH = rl(AH);
#asm // 17
MOVF Dat+1,W
ADDWF AL+1,1
MOVF Dat,W
ADDWF AL,1
BTFSS 0x03,Carry
GOTO keinCarry
BCF 0x03,Carry
INCF AL+1,1
BTFSC 0x03,Carry
INCF AH,1
keinCarry:
#endasm
Lesen(AH,AL); // 18 Erste Block des Clasters
Carry=0; // 19
AL++;
if(Carry)AH++; // Hier werden Grenzen der wariable berücksichtigt
Lesen(AH,AL); // 20 Zweite Block des Clasters
AL=FAT; // 21 nexte Claster
temp=ByteLes/0x100;
AL=AL+temp; // 22
temp=temp*0x100; // 23
BytN=ByteLes-temp;
BytN=BytN*2;
Byte_lesen(); // 24
while(1);
ur help of getting me through the project is appreciated
:D
Use a language translator tool & get the idea.There are plenty on the web.
looks like German maybe ...
It appears to be some code for handling an MMC Memory Card. Code is code and you really should not need the comments especially for things like initializing the UART and the SPI Port. A FAT is a file allocation table and it gives you information on the files on the MMC card. This program would be more understandable if you knew what the format of the data on an MMC card was. Do you know anything about MMC cards? I personally don't know much more about them then I've already written.
The comments are in German so you should be able to decode them with a German English dictionary. Give it a go, it's actually fun poking into another language.
