Can anybody Help me build a simple Basic Electronics project
Innocent Gudiya
I just want to make a simple project related to Basic Electronics. First I have to create it on breadboard and then on PCB. Can anyone suggest me some projects? I am fed up of searching them.
Thankew..
How basic? In order to give you suggestions, we need a lot more information. What is this for? Is this a school project? Can you use simple ICs? What have you already considered? Is there a space requirement?
I'd suggest trying a basic LED flasher circuit. You can build one using a 555 timer chip and some resistors/capacitors, or you can build one using transistors instead of the chip. But like I said, we'll need a little more information first.
I would suggest a simple radio circuit. Perhaps a crystal radio. Or it may be a good idea to start off with one of the many kits available.
I recommend building a variable output DC power supply. Useful features would include a meter showing output voltage and/or output current, and a current limiting circuit. The part that connects to the mains should be purchased as a module so that you are not exposed to dangerous mains voltages. Output of the module would be a suitable lower voltage like 15 Volts or 24Volts AC.
power supply, audio amp, fm transmitter, regen receiver, chasing lights, timer, counter, logic probe, ...
