Can anyone help- UART Commn
rameshelectro
I used microC for pgmming 18f4520. the pgm aim is to transmit the same data back to terminal.But what i get is different.
send data:hi dere
received data:ø8øø
Code goes here:
void main() {
unsigned char Temp;
trisb=0x00;
Uart1_Init(9600);
Delay_ms(25);
latb.b1=1;
Delay_ms(50);
UART1_Write_Text("Start");
UART1_Write_Text(" ");
latb.b1=0;
for(;; )
while (!UART1_Data_Ready());
Temp = UART1_Read();
latb.b1 = ~latb.b1;
Delay_ms(50);
UART1_Write(Temp);
latb.b1 = ~latb.b1;
Delay_ms(50);
check the baud rate on your pc, check your crystal.. (if you are using one)
check whether the internal oscillator is calibrated correctly... the config bits of pic 18f series are a bit confusing. Double check the config bits.
