Sathiesh Kumar
I am doing control area network project... where i have to sense the temperature value in one node and i have to transmit it to the other node using CAN Bus..The problem is that the lcd just display "Temp= _ ". I will attach the code ...can anyone help me to solve the problem...
Microcontroller
IC 18F458
Oscillator:20 Mhz
Compiler:MikroC
CAN Tranceiver:MCP2551
Display.C
/*The LCD is connected to the microcontroller as follows:
Microcontroller LCD
RC0 D4
RC1 D5
RC2 D6
RC3 D7
RC4 RS
RC5 EN
CAN speed parameters are:
Microcontroller clock: 8MHz
CAN Bus bit rate: 100Kb/s
Sync_Seg: 1
Prop_Seg: 6
Phase_Seg1: 6
Phase_Seg2: 7
SJW: 1
BRP: 1
Sample point: 65%
File: DISPLAY.C
void main()
unsigned char temperature, data[8];
unsigned short init_flag, send_flag, dt, len, read_flag;
char SJW, BRP, Phase_Seg1, Phase_Seg2, Prop_Seg, txt[4];
long id, mask;
TRISC = 0; // PORTC are outputs (LCD)
TRISB = 0x08; // RB2 is output, RB3 is input
// CAN BUS Parameters
SJW = 1;
BRP = 1;
Phase_Seg1 = 6;
Phase_Seg2 = 7;
Prop_Seg = 6;
init_flag = CAN_CONFIG_SAMPLE_THRICE &
CAN_CONFIG_PHSEG2_PRG_ON &
CAN_CONFIG_STD_MSG &
CAN_CONFIG_DBL_BUFFER_ON &
CAN_CONFIG_VALID_XTD_MSG &
CAN_CONFIG_LINE_FILTER_OFF;
send_flag = CAN_TX_PRIORITY_0 &
CAN_TX_XTD_FRAME &
CAN_TX_NO_RTR_FRAME;
read_flag = 0;
// Initialize CAN module
CANInitialize(SJW, BRP, Phase_Seg1, Phase_Seg2, Prop_Seg, init_flag);
// Set CAN CONFIG mode
CANSetOperationMode(CAN_MODE_CONFIG, 0xFF);
mask = -1;
// Set all MASK1 bits to 1's
CANSetMask(CAN_MASK_B1, mask, CAN_CONFIG_XTD_MSG);
// Set all MASK2 bits to 1's
CANSetMask(CAN_MASK_B2, mask, CAN_CONFIG_XTD_MSG);
// Set id of filter B2_F3 to 3
CANSetFilter(CAN_FILTER_B2_F3,3,CAN_CONFIG_XTD_MSG);
// Set CAN module to NORMAL mode
CANSetOperationMode(CAN_MODE_NORMAL, 0xFF);
// Configure LCD
Lcd_Config(&PORTC,4,5,0,3,2,1,0); // LCD is connected to PORTC
Lcd_Cmd(LCD_CLEAR); // Clear LCD
Lcd_Out(1,1,"CAN BUS"); // Display heading on LCD
Delay_ms(1000); // Wait for 2 seconds
// Program loop. Read the temperature from Node:COLLECTOR and display
// on the LCD continuously
for(;
// Endless loop
Lcd_Out(1,1,"Temp = "); // Display "Temp = "
// Send a message to Node:COLLECTOR and ask for data
data[0] = 'T'; // Data to be sent
id = 500; // Identifier
CANWrite(id, data, 1, send_flag); // send 'T'
// Get temperature from node:COLLECT
dt = 0;
while(!dt)dt = CANRead(&id, data, &len, &read_flag);
if(id == 3)
temperature = data[0];
ByteToStr(temperature,txt); // Convert to string
Lcd_Out(1,8,txt); // Output to LCD
Delay_ms(1000); // Wait 1 second
Collector.C
Sync_Seg: 1
Prop_Seg: 6
Phase_Seg1: 6
Phase_Seg2: 7
SJW: 1
BRP: 1
Sample point: 65%
File: COLLECTOR.C
void main()
unsigned int temp;
unsigned long mV;
long id, mask;
TRISA = 0xFF; // PORTA are inputs
// Configure A/D converter
ADCON1 = 0x80;
// CAN BUS Timing Parameters
SJW = 1;
BRP = 1;
Phase_Seg1 = 6;
Phase_Seg2 = 7;
BRP = 1;
Prop_Seg = 6;
CAN_TX_XTD_FRAME &
read_flag = 0;
// Initialise CAN module
mask = -1;
// Set id of filter B1_F1 to 3
CANSetFilter(CAN_FILTER_B2_F3,500,CAN_CONFIG_XTD_MSG);
// Program loop. Read the temperature from analog temperature
// sensor
for(;
// Endless loop
// Wait until a request is received
dt = 0;
while(!dt) dt = CANRead(&id, data, &len, &read_flag);
if(id == 500 && data[0] == 'T')
// Now read the temperature
temp = Adc_Read(0); // Read temp
mV = (unsigned long)temp ∗ 5000 / 1024; // in mV
temperature = mV/10; // in degrees C
// send the temperature to Node
isplay
data[0] = temperature;
id = 3; // Identifier
CANWrite(id, data, 1, send_flag); // send temperature
Microcontroller
Oscillator:20 Mhz
Compiler:MikroC
Display.C
Microcontroller LCD
RC0 D4
RC1 D5
RC2 D6
RC3 D7
RC4 RS
RC5 EN
Sync_Seg: 1
Prop_Seg: 6
Phase_Seg1: 6
Phase_Seg2: 7
SJW: 1
BRP: 1
Sample point: 65%
File: DISPLAY.C
void main()
long id, mask;
SJW = 1;
BRP = 1;
Phase_Seg1 = 6;
Phase_Seg2 = 7;
Prop_Seg = 6;
CAN_TX_XTD_FRAME &
read_flag = 0;
mask = -1;
// Configure LCD
for(;
dt = 0;
if(id == 3)
Collector.C
Sync_Seg: 1
Prop_Seg: 6
Phase_Seg1: 6
Phase_Seg2: 7
SJW: 1
BRP: 1
Sample point: 65%
File: COLLECTOR.C
void main()
unsigned int temp;
unsigned long mV;
long id, mask;
ADCON1 = 0x80;
SJW = 1;
BRP = 1;
Phase_Seg1 = 6;
Phase_Seg2 = 7;
BRP = 1;
Prop_Seg = 6;
CAN_TX_XTD_FRAME &
read_flag = 0;
mask = -1;
// sensor
for(;
dt = 0;
