Just thinking a few things through and it got me wondering, the set up is say a model train set with inductors between the rails (smd and small), now I now if you put a clocked pulse through an inductor them pass metal over it the frequency changes. There are a few on the net based around WDT etc, and I have done one with a timer etc.
This got me wondering, supposing you wanted more detectors then you would need something else. Do you think the following would work, the CTMU detects the charge on a cap over a sampled time. Depending on that charge determines if the capacitance has changed. So could the same be done using inductors connected to the CTMU channels?
Pass say a fairly high frequency low voltage/current at low duty cycle through the inductor and measure with the CTMU, no metal and the reading will be what ever charge has accumulated, pass metal over the inductor and would this alter the amount of charge by stretching the frequency or duty cycle therefore changing the amount of charge read by that CTMU channel. Obviously you set the CTMU to take readings at a set time period via timers so this is constant.
Thoughts ?
The distance between inductor and moving metal is only 2-3mm so that bit should work. If it does work then there are chips that have a good number of captouch channels and this would make it viable to have large numbers of train detection units along a track.
OK now explain why it wont work
have I tried it? I dont want to say yet, first I wont to get reactions
Thoughts ?
