Richardcavell
Hi. I'm building relatively simple electronic circuits to teach myself the basics. I'm doing the first 21 pages' worth of circuits from Jaycar's Simple Circuits Volume I. The most complicated circuit is an astable multivibrator using 2 transistors.
My local electronics shop has all kinds of cables and connectors. VGA, RF, serial port... all manner of connectors. I had the idea of using some of these connectors in my circuits. For example, I could separate the two halves of the oscillator circuit and connect them (or indeed any other two halves) using a VGA cable. I would have to select a few pins to use to bridge the broken part of the circuit, and wire in two sockets.
My intention is not to use the protocol that goes along with the relevant connector/cable. So, for example, if I actually plugged part of my circuit into a VGA socket, I'm not expecting a monitor to display anything meaningful. (Or it could even blow up).
Am I right in thinking that the cables are just conductive wires inside, so I can simply use them arbitrarily?
Richard
Richard
