Can i make these more sturdy?
Doomguy42
Hi, most of the boards I work on have Rows of these Darlington transistors. Is there any accepted way to make them more sturdy? They obviously generate some heat so I was wondering if there's any thing professional's do.
I'd suggest these https://www.mcmaster.com/nylon-standoffs/male-female-threaded-hex-standoffs-6/ in nylon.
If you wanted to do metal then you would need shoulder washers.
I'm assuming the tabs are not electrically connected.
Another way is shoulder washers for each transistors, a nylon spacer and a piece of 4-40 all thread.
You might have to tweek a few solder joints, but it would be easier to insert. Nuts and a bellville washer.
They've been fine for the last 31 years, any attempt to "fix" it will likely end up in Sadness. I would look for a more protective chassis. What is it? A pen-plotter or chart recorder or...?
That looks like a pinball driver board.
That was my first thought. So much so that I thought I'd check how mine were supported, they're not.
As previously stated, they've worked fine like this for a (very) long time and will continue to do so.
