jocanon
I was looking at the below switch and my question is, instead of using the Quick Connect connector, can I solder bare wire directly onto the Quick Connect leads or will that break the switch somehow? Before anyone suggests getting a switch with solder lugs...I already know those are out there and have one in mind if this one doesn't work, but I like the round switch and the only one I can find that is rated up to 20 amps at 125v with solder lugs is square. I will get the square one if I have to, but round is easier to work with. That being said, if anyone knows a round one with solder lugs that would be the better solution. Thanks!
https://www.digikey.com/product-detail/en/RR511D1121/EG4777-ND/2116256
