The title mentions Optocoupler's where I assume the distance is 0.1 inch in the dark. If you bias the LED so 2mA is flowing all the time and then with analog audio modulate the current from 1 to 3mA you will get audio on the transistor side of the Optocoupler. Running the Optocoupler's in linear mode makes it pretty fast. There will be some distortion.Can I transmit audio through light using Optocoupler's working theory?
By connecting sound waves to LED (it will light according to sound waves) and receiving the transmitted sound light by using photo transistor or LDR or photo diode. Or any possibilities?
They are very slow. 100hz is about as fast as I got from a LDR.
very fast!!! 100mhz Must see a strong signal.photo diode
