Quick question: Can I wire ground straight through?
Hi there,
I would like to put a manual power switch on the back of an LCD monitor I'm modding (based on this).
That is, as opposed to having to switch the monitor's power off at the wall, I'd like to have a switch on the back of monitor for easier access. Reason being: my monitor has decided that when it is receiving power but not a video signal, it will make an annoying high pitched noise - so I want to be able to easily disconnect the power.
I plan to unsolder the IEC socket on the monitor and put a DPST in. I've got a DPST switch (it's rated at 250VAC and 6A) and I know this will work for switching the L and N wires on and off - however it seems my monitor also uses the ground wire.
Can I run the ground straight from the IEC through to the rest of the board's electronics and only disconnect the power via L + N? Or must L, N and ground ALL be switched off for this work, necessitating some kind of triple-pole switch?
Hi there,
