That's a meaningless question.
What do you mean by most op-amps? You haven't given any examples.
It depends on the peak output voltage and the gain of the design.
The µA741 has a full power bandwidth of only 8kHz and its gain goes down to unity at 700kHz (worst case). For example you can use it at 50kHz with a gain of say 3 with an output voltage of just 500mVp-p but it you want 10Vp-p then forget it.
Op amps are generally used at low voltage and power levels. Radio station transmitters use massive high power amplifiers with large discrete devices These have little similarity to an op amp other than that they are both amplifiers. There are generally multiple stages of amplifers between the low level signals and the transmitter output.Hmm, I dont get it. Radio stations need massive amounts of current to transmit their signals and they need to create sinusidal waves to do it with, how do they create so much current if op amps cant handle so much voltage??
Sounds like you need to look up some basic tutorials on ampliifers and electronics.
He is trying to make a radio station with a single opamp.
Well, a uA741 will swing about 0.2Vpk at 500KHz.... how far does it have to transmit![]()
Do you have a licence from the government to operate a radio station? On thier chosen frequency?
Has the government passed your promised type of music/talk?
Is the radio transmitter certified so that it does not cause interference?
