lompa said:Can anyone explain why some plc's/outstations have isoloated I/O and some have non-isolated I/O's
What does the term isolated mean
and why are there two methods for PLC/RTU/Outstations?
Nigel Goodwin said:To go back to a long recurring discussion, about earthing scopes!.
Assume you have an earthed scope, and you attempt to connect it to the chassis of a switch mode mains PSU - there will be a big BANG, because there's a direct connection between the scope ground (which is probably earthed - but not at my house!) and the live mains in the PSU.
Electrix said:You are again assuming that the PSU is at fault and therefore its chassis is at live potential. Hovever this may be a rare case if you take precautions to ensure that the chassis of the PSU is also at earth potential by using an earthed chassis PSU. If you are 100% sure that this is the case then I would not worry about isloation at all !
Nigel Goodwin said:Electrix said:You are again assuming that the PSU is at fault and therefore its chassis is at live potential. Hovever this may be a rare case if you take precautions to ensure that the chassis of the PSU is also at earth potential by using an earthed chassis PSU. If you are 100% sure that this is the case then I would not worry about isloation at all !
I'm NOT assuming that, and NEVER have - the primary side of a SMPS is ALWAYS at live potential (unless you feed it through a conventional isolation transformer).
Electrix said:Nigel Goodwin said:I'm NOT assuming that, and NEVER have - the primary side of a SMPS is ALWAYS at live potential (unless you feed it through a conventional isolation transformer).
ok.. i was unaware that the chassis of the SMPS is always at live potential... :?
if thats the case, then ur right.. u just can't afford to connect an earthed scope the chassis....
