I'm flipping through datasheets and it seems like most op amps boast high gain, bandwidth, low noise.... and so on and so forth.... but I can't figure out which would be good for my application....
I don't care about gain, I don't care about bandwidth....
I'm looking for an opamp that I can use as a unity gain buffer, with negative feedback (no feedback resistor though) and I will be inputting a DC voltage on it's non-inverting input, and I want to see that same DC voltage on the output...
but, I'm having two problems... first, I'm not exactly sure what criteria I need to be looking for, I've heard that op amps with high bandwidth may have trouble with unity gain... or that some op amps in general may have trouble with unity gain...
could someone tell me what criteria I need to be looking at? or can anyone recommend any op amp that can do this well?
much thanks!
extra info:
I will be driving an RC circuit with my op amp.... if it helps any to see what I'm trying to do... the next two pics show my circuit... I'm basically trying to make a pos/neg voltage supply I can control with a 4-20mA current, and I need my output voltage to clamp at a low level and a high level....
much thanks!
extra info:
