can this be hard infrared remote control
sherial
banggood electronics
Hi,I started a program recently,I suppose this should be interesting,but i need some help
Can anyone suggest me a circuit for a 2 or 3 channel infra red remote control.I wanna make my AF Power Amp controlled with a remote.
I have got a circuit here
IC1 is a Op Amp - LM308
IC2 is some kind of tone decoder - LM567
Why not make your title "2-3 channel infrared remote control" or "Remote Controlled AF Power Amp" instead of "can this be hard"?
You may ask a moderator to change it for you.
Well, this is just my suggestion thinking that you may get more replies that way.
It's still up to you :D :D :D
I would use a carrier frequency and then modulate onto that one of 3, 4, 5 or 6 different frequencies (sound up, sound down, chan up, chan down, power on, power off). The main carrier would descriminate against any other remote, and the modulation frequency would work the controls. Or, you could use dtmf, since they have a single chip that decodes the multiple frequencies for you and gives a valid output command.
