madiarasias
Hi everyone.
I'm trying to draw out a wiring diagram of this 2.4 kilowatt heaterand theres some parts I cant name, I have the product codes here ..
Anyway to begin with I'll describe it : The phase wire supply comes in to the chocolate box terminal then out towards the heating element where it enters into a white ceramic box about as big as a childs thumb, it is stamped 'Microtemp G4AM0600'. The phase comes out there and into a similar size ceramic box with a penny sized metal plate sticking down towards the heating element, this one is stamped '5900074'. Thence the phase wire goes back to the dial switch thingy.
Now from this dial switch there is a phase going to the element and a neutral going back to the supply, which is fine. But there is also another, smaller, phase going from the dial switch to the heating element, and it plugs in to a spade terminal right next to the main phase.
Now I'll just go on and on ...... There is a 3rd phase going to a thin metal plate mounted on plastic just above the switch contraption, it is stamped '155CTB1577B 16A 250V' and it goes back to the selector switch. There is a 4th phase which supplies the fan motor and on its way there it goes through someting stamped 'irh PW 20 470 R K'.
So finally thats everything.phew.
I'd like to know what is/are:
1)The microtemp G4AM0600 thats wired in series with the 5900074 between the supply and the selector dial
2) The 155CTB1577B that is on a loop of wire coming in and out of the selector dial
3)The irh PW 20 470 RK that is between the selector dial and the fan motor
4)The smaller phase wire that goes from the selector dial to the heating element.
Thanks for your time, google hasnt helpled me identify these things so even and educated guess would be appreciated.
XD cheers
XD cheers
