Hi guys I'm new here and this is my first post
I have a homework to simulate and calculate the poles and the zeros of the compensation circuit of a buck converter.
I've set up all the circuit and done all the simulations
The problem is that i'm stuck at calculating the near zero pole because i cant locate on the datatsheet the Roea value for this chip.
The component used is LT3864(datasheet https://www.electro-tech-online.com/custompdfs/2012/12/3864f.pdf) from Linear
As shown in this linear application note (https://www.electro-tech-online.com/custompdfs/2012/12/an76.pdf page 5) the first pole is calculated using the Roea
I cant really find whats the value of Roea for this component.
Can you you please give a look at the datasheet?
