bigkim100
Banned
Just to get everyone up to speed here is the original post-
I have a small tank (about the size of a pop can) that is made out of plastic, and I need to monitor the water level inside. I CANNOT USE PROBES..no matter what, so does anyone have a circuit that can be used that uses capacitance in such a small container. I only need to know when the level gets low, not terribly accuratly, BUT the circuit does need to ignore short bursts of the tank "sloshing" the water around. .Again, the circuit only needs to trigger when there is about 1/2 to 1 inch of water in the container, after being full.
Is the "sloshing" sensor part of this something that only a microcontroller can do, or can a analogue way be designed.
So Im going to use some of the ideas given for the sensor....now its time to ask about the "Slosh Rejection" part of the project
The circuit does need to ignore short bursts of the tank appearing to be empty when the contents are "sloshing" around.
Again, I would prefer a non-microcontroller answer to the question, and tye circuit must be battery powered.
Again....the stats for this job are not very tight, it is not a life-or-death application.
