ChrisP said:That is a 4mm diameter x 7mm high radial lead miniature electrolytic cap...
ChrisP said:If you know who the maker of a component is, you can generally go to that company's website and obtain the dimension information for the device in question. Another good source would be the catalogs offered by the component distributors.
In the case of the capacitor about which you asked, I simply went to the Maplin site and drilled down to Components > Capacitors > Electrolytics > Miniature 7mm Radial Electrolytic Capacitors (on the menu at the left side) and verified that the catalog number that you want (VH04E) was listed in that section, and that the catalog number matched the values that you posted. The dimensions for the devices in that catalog section are listed there as well.
