speakerguy79 said:Generally not a good idea unless you know how the ckt works exactly and what they might be subjected to. Electrolytics would be cheaper anyway.
stevez said:mopar - I am less than an expert in this area but your problem description says "some bad electrolytic capacitors" - a cause for concern even if you find exact replacements.
Capacitors do fail as do other components but to fail together suggests that something - over temp, overvoltage, etc - caused the failures. Replacing the caps would likely not address those failures unless the cause were removed.
Krumlink said:Maybe they dried out? Electrolyics can suffer that, so I would replace them, but should the problem arise again, take it to a TV repair specialist.
Hero999 said:Electrolytics often go bad, you might be able to replace them with tantalums and the chances are it will be more reliable if you do.
Nigel Goodwin said:As usual - not in my experience in TV's!
Replacing using good quality electrolytic, and using 105 degree ones (not the usual 85 degree), should easily outlast the TV.
I agree, but I've heard you complaining about unreliable tantalums and I'd disagree. I've never seen a tantalum go bad before, but I've seen plenty of electrolytics go bad in my time. I would think that your bad experiance probably be due to a dodgy Chinese supplier providing you with cheap knock-offs.Nigel Goodwin said:As usual - not in my experience in TV's!
Replacing using good quality electrolytics, and using 105 degree ones (not the usual 85 degree), should easily outlast the TV.
Hero999 said:I agree, but I've heard you complaining about unreliable tantalums and I'd disagree. I've never seen a tantalum go bad before, but I've seen plenty of electrolytics go bad in my time. I would think that your bad experiance probably be due to a dodgy Chinese supplier providing you with cheap knock-offs.
What TV repair? that still exists?Krumlink said:Maybe they dried out? Electrolyics can suffer that, so I would replace them, but should the problem arise again, take it to a TV repair specialist.
crusty said:What TV repair? that still exists?
chemelec said:LOTS Of Repairs Still. Especially Warranty Stuff.
But Most are Big Screen TV's and Most are really just Replacing Whole Boards. Not Individual Components.
