Capacitor Value
codan
I have a Plessey AC Motor Start Electrolytic Capacitor USA from a 240v single phase motor that i am trying to get the specifications for, unfortunately most of the writing is worn off so the exact specs are not known:
It is Black in colour, 52mm dia X 112 long, it's hard to make out but it looks as if it might have said 230v?
There is some of the part number remaining but the first & last digits are hard to read.
It looks like 677-9230-1 or 377-9230-1
Can someone help out or is there a site i can go to to look for it?
Do you know the capacitance?
Have you measured it?
Assuming it's rated for AC you could connect it up to the mains with a 3W 10R series resistor. Measure the voltage across the resistor to determine the current; calculate: the capacitor's reactance at the mains frequency and then the capacitance.
The chances are that most non-polarised capacitors that can handle the current and voltage will be fine.
No, the capacitance value is worn off & is the value i need to know, 10R resistor is that 10 Ohms.
What calculation do i need to work out the capacitance value from voltage across the resistor?
Assuming that R is small compared to Xc:
[latex]
I = \frac{V_R}{R}\\
X_C = \frac{V}{I} \\
C = \frac{1}{2 \pi X_CF}\\
V_R = \text{Voltage measured across the resistor.}\\
R = \text{Resistor value.}\\
X_C =\text{Reactance of the capacitor.}\\
I = \text{Current}\\
F = \text{Mains frequency} [/latex]
Check it with an ohmmeter first.
If you put more than a few volts/amps into the cap, wear face protection.
