shaneshane1
just wondering if it matters what sort of cap is used to smooth out voltage spikes, couldnt i use a cap of a higher value than recommended?
a caps discharge is done by the load, so if i dont mind my application running a little longer after the power is turned off, what does it matter what cap i use, as long as it is higher than it recommended value shouldn't it work just as good?
