It doesn't sound a very good idea! - but you don't give many details for us to base a judgement on. Exactly which capacitor in what sort of power supply is it?.
Sorry I looked at the cap, and thought it was deformed! But its ok! The cap is part of the switch-mode power supply. The cap is 270uF 200 volts , but going through my junk The only thing I had close was a photo flash cap rated at 300 volts. I was just thinking that the Photo Flash might of worked
Photoflash caps are electrolytics. But they're not usually rated for continuous duty. I'm not sure if you can compare the capacitance and voltage rating on the package as being equivalent to a general purpose electrolytic. Probably not a good thing to try.
I know the exact model number of photo flash I have and they don't even list a ESR There's a reason for that, they're produced in bulk and cheaply with wide variances to reduce cost, so the individual device to be used would have to be tested in order to determine if it were okay for use under anything but short pulses infrequently. Even a badly manufactored capacitor is going to last a pretty long time when used at the rate that a disposable camera flash is. I've never taken any apart (they're expensive obviously) so I don't know what kind of capacitors higher end cameras use.
