CATV Amplifire
E2K
Hi All
Last month I've faced Cable signal problem, I cann't
received most T.V stations clearly. So I've bought a CATV signal
Amlifire (made by china). But it is not working so well. Please
tell me how I can increase the Power of Amplifire.
If you have a weak TV signal, that is stations there that are weak and have snow in the display, the amplifier is not going to help as it will make things worse as it is going to amplify the noise.
k7elp is right, all you're going to do is make the problem worse. Call your cable company instead. Those amplifiers are only really useful if you have a decent signal coming in and want to distribute it to a lot of TV's in which case it's the first device attached to your cable system and you connect everything else to it.
