CCS Compiler: Interrupts
i2c2k
Hi!
I tried to write interrupts but the code doesn't work on my PIC16F876A:
CCS C-Compiler Code:
#include <16f876A.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use delay(clock=4000000)
inthdl_ext();
void main() {
   SET_TRIS_A ( 0b11111010 );
   SET_TRIS_B ( 0b00000001 );
   SET_TRIS_C ( 0b00000000 );
   enable_interrupts(INT_EXT);
   ext_int_edge(H_TO_L);
#INT_EXT
inthdl_ext() {
   output_bit(PIN_A2, 1);
   delay_ms(2000);
   output_bit(PIN_A2, 0);
The LED on Ra2 should be on for 2 seconds, but it doesn't unfortunately.
By the way putting "void" before "inthdl_ext()" does not affect the result.
cya
i2c2k[/code]
Thanks!
The fnterrupt works fine!
Does anybody know, how my C-Code can recognize, which of several buttons is pressed, when I have only one interrupt line and one input-pins for each button?
cya
i2c2k
Yes, that's clear, but how do I supply two inputs (1 for interrupt, 1 for which button is pressed) with only one button?
                              T
                +5V----o-----o o------o--------------- Key 1 IN
                       |              o->|-o
                       |      T            |
                       o-----o o------o----|---------- Key 2 IN
                       |              o->|-o
                       |      T            |
                       o-----o o------o----|---------- Key 3 IN
                                      o->|-o---------- interrupt IN
                                     3x 1N4148
created by Andy´s ASCII-Circuit v1.24.140803 Beta [url]www.tech-chat.de[/url]
this one 'or's all keys to the interrupt pin.
hth
joachim
edit: sorry, i forgot the pulldown resistors.
