Cellular interference
EngIntoHW
I read that:
Engineers discovered that the interference effects were not due to the distance between areas, but to the ratio of the distance between areas to the transmitter power (radius) of the area
Did they mean that Interference = R / D
D - Distance between areas
R - Radius of each area
It makes sense to me, just wanted to verify it.
Perhaps you know where I could read more about it?
Thank you.
See PDF. Note that this is just an idealization. In real life every site is analyzed on a case-by-case basis to see where shadowing by things like hills, valleys, and large clusters of tall buildings and the locations of towers are decided from that uniquely generated map to get total coverage.
It's just a ratio or factor though so it doesn't really matter whether it's upside down or right side up. As long as you know what it means the way it is written and use it correctly in that context.
  • notes.pdf
