71challenger
Hi I have a pair of the very small Advent speakers using them as rear surrounds. The amp driving these is rated @100wrms x2 @8 ohms. I need to change the impedance of these from 8 to 4 ohms to compensate for my seperate front channel amp rated at 300 wrms to compensate for the difference in volume at lower listening levels. Granted I can't use all the power before it clips or I go deaf ,The loudest I play it for movies is about -58db and -27db for music. Correct me if I'm wrong, but I think I need to Parellel an 8 ohm wire wound resistor across the Advents To give me better balance (from the front and rear amps) at a lower listening level. What wattage of resistor? 75watt?
Thanks in advance
Thanks in advance
