This project derived from Bobledoux project.
I want to charge a 470uF capacitor to 35V, then discharge it into a solenoid. The two actions will be separated by PIC control.
I'm using this board by now: 9V battery, .14 Period and .3 Duty give me 14mA draining during recharge, 9mA when fully charged, about 14seconds to full charge.
Battery life and dimension is the problem: it's too short the first one, too big to fit project.
I tested the board discharging 80times during 2hours, first load battery is 9,20V, after the test is at 8.60V, doesn't sound great to me, i need at least 3000 cycles with one battery.
I made some calc:
Energy in cap = 0.5 x C x V^2 = 0.5 x 4.7x 10^-4 x 35^2 = 0.2879 Joule
solenoid request is 130W x 0,002seconds discharge = 260mW assuming 60% efficency = 433mW
If powered by 3V battery, 20mA x 3V = 60mW ... 433/60 = 7 seconds to recharge, near my goal: 24mA = 6sec recharge time.
As for battery i was thinking about cr2450, but datasheet refer "continuous standard load" as low to 0,20mA, others indicate as not too much life reduction with 10mA, both value are far away my calc (20-30mA).
By now i tested the second board attached, lot of problems: mainly i must double VRCON value to obtain the same level, and i don't know why; plus the battery pack (2xAA) is too big to fit inside real project but i cannot use coin cell because of too high current draw.
Wich is the right way to make the board functioning with 2xAAAA, at least 3000click?
Thanks,
best regards,
LukeP.
I made some calc:
Thanks,
best regards,
LukeP.
