NJ Roadmap
An obvious problem when using RF transreceivers for data transmission is the possibility of another transmitter transmitting at the same time and hence causing interference.
Obviously simple addressing will make sure the data is only processed by the intended receiver, but how would one prevent transmitter interference if you can't change frequency channels on cheap transmitter modules? This isn't a problem currently, but I'd like to know whether theres a solution other than making sure that the transmitting ranges of two transmitters do not overlap.
