sorry guy but i missed myself, i don't know why my code doesn't work, could someone help me e chek it,please?
title "PIC16F73"
list p=16f73,f=inhx32
#include <p16f73.inc>
MSGPTR EQU 0x26 ;General purpose register
BITS EQU 0x27 ; General purpose register
CNTMSEC EQU 0x28 ; General purpose register
ZEROBIT EQU 0x02 ;Zero bit of Status Reg
DELAY1_VAL1 EQU 0x21
DELAY1_VAL1_TEMP EQU 0x22
DELAY2_VAL1 EQU 0x23
DELAY2_VAL1_TEMP EQU 0x24
TMR0_TEMP EQU 0x25 ;Used for storing TMR0 during interrupt
W_TEMP EQU 0x29 ;Used for storing W during interrupt
SPBRG_VAL EQU 0x30 ;set baud rate 9600 for 4Mhz clocK
PAUSE_DELAY EQU 0x31
CBLOCK 0x020
Flags ;byte to store indicator flags
ENDC
ORG 0x00 ;reset vector
GOTO Start
ORG 0x08 ;Origin for the external RA0/INT
DELAY1 MOVLW 0xB2 ;No. of outer loops is 0xFF-val
MOVWF DELAY1_VAL1 ;
LOOP2 MOVLW 0x01 ;No. of inner loops is 0xFF-val
MOVWF TMR0
BANKSEL OPTION_REG ;
MOVLW B'11000111' ;set prescaler to 256
MOVWF OPTION_REG ;
BANKSEL PORTA
LOOP1
MOVF TMR0,0 ;Affects the Z bit of STATUS
BTFSS STATUS,ZEROBIT ;See if Z bit is set
GOTO LOOP1 ;No, check again
INCF DELAY1_VAL1,1 ;yes, inc DELAY1_VAL1 Affects Z bit
BTFSS STATUS,ZEROBIT ;used to see if DELAY1_VAL1 is zero
GOTO LOOP2 ;NO - start inner loop again
RETLW 0 ;YES - return from DELAY1
DELAY2 MOVLW 0xFE ;No. of outer loops is 0xFF-val
MOVWF DELAY2_VAL1 ;
LOOP4 MOVLW 0x01 ;No. of inner loops is 0xFF-val
MOVWF TMR0
MOVWF OPTION_REG ;
BANKSEL PORTA
LOOP3
GOTO LOOP3 ;No, check again
INCF DELAY2_VAL1,1 ;yes, inc DELAY1_VAL1 Affects Z bit
GOTO LOOP4 ;NO - start inner loop again
Start
;Interrupt Initialisation
MOVLW B'00000000' ;Sets GIE and PORTB int.
MOVWF INTCON ;allows interrupt to be applied on PORTB<7:4>
;PORTs Initialisation
BANKSEL PORTA ;select bank of PORTA
CLRF PORTA ;
CLRF PORTB
;Port configuration
BANKSEL TRISA
MOVLW 0xFF ;Configure Port A
MOVWF TRISA ;as Inputs
MOVLW B'00000000' ;Configure Port B
MOVWF TRISB ;Outputs =0,1,2,3,4,5,6,7
MOVLW B'00000000'
MOVWF TRISC ;Configure PORTC as output
BANKSEL PORTA ;Select bank of PORTA
MOVLW B'00000000' ;All PORTC's output =0
MOVWF PORTC ;
;TX UART initialilsation
BANKSEL TRISA ;select bank 1
MOVLW 0xc0 ;set tris bits for TX and RX
MOVLW SPBRG_VAL ;set baud rate
MOVWF SPBRG
MOVLW 0x24 ;enable transmission and high baud rate
MOVWF TXSTA
BANKSEL PORTA ;select bank 0
MOVLW 0x90 ;enable serial port and reception
MOVWF RCSTA
;Set the address
OUTMSG MOVWF MSGPTR ; put 'W' into message pointer
MSGLOOP MOVF MSGPTR, W ; put the offset in 'W'
CALL MSGTXT ; returns ASCII character in 'W'
MOVWF PORTC ;
ADDLW 0 ; sets the zero flag if W = 0
BTFSC STATUS, 2 ; skip if zero bit not set
RETURN ; finished if W = 0
CALL OUTCH ; output the character
INCF MSGPTR, f ; point at next
GOTO MSGLOOP ; more characters
MSGTXT
ADDWF PCL, f ; offset added to PCL
RETLW d'1' ; 1
RETLW d'84' ; 84
RETLW 0x63 ; 'c'
RETLW 0x6F ; 'o'
RETLW 0x6E ; 'n'
RETLW 0x20 ; 'space'
RETLW 0x30 ; '0'
RETLW 0x30 ; '0'
RETLW 0x3A ; ':'
RETLW 0x30 ; '0'
RETLW 0x43 ; 'C'
RETLW 0x3A ; ':'
RETLW 0x38 ; '8'
RETLW 0x34 ; '4'
RETLW 0x3A ; ':'
RETLW 0x30 ; '0'
RETLW 0x30 ; '0'
RETLW 0x3A ; ':'
RETLW 0x30 ; '0'
RETLW 0x45 ; 'E'
RETLW 0x3A ; ':'
RETLW 0x44 ; 'D'
RETLW 0x34 ; '4'
RETLW 0x00 ; end of seding routine (acts as stop bits)
OUTCH MOVWF TXREG ; put W into transmit register
MOVLW 8 ; eight bits of data
MOVWF BITS ; count bits
;BSF PORTA, 1 ; start bit on RA1 CHEK////////////////////////
TXLOOP MOVLW 0x31 ; 49 decimal, delay time
CALL MICRO4 ; wait 49 x 4 = 196 microseconds
RRF TXREG, f ; rotate right most bit into carry
BTFSC STATUS, 0 ; if carry 0 want to set bit, ( a low )
GOTO CLRBIT ; else clear bit, ( a high )
;BSF PORTA, 1 ; +5V on pin 1 ( RA1 ) CHEK//////////////////
GOTO TESTDONE ; end of character?
CLRBIT ;BCF PORTA, 1 ; 0V on pin 1 ( RA1 ) CHEK /////////////////
NOP ; to make both options 12 micosec (ylp-"NOP")
TESTDONE DECFSZ BITS, f ; 1 less data bit, skip when zero
GOTO TXLOOP ; more bits left, delay for this one
MOVLW 0x34 ; full 208 microsec this time
CALL MICRO4 ; delay for last data bit
;BCF PORTA, 1 ; 0V, ( a high ) for stop bits CHEK/////////////////
MOVLW 0x68 ; decimal 104 delay for 2 stop bits
CALL MICRO4
RETURN
NMSEC MOVWF CNTMSEC ; W to msec count register
MSECLOOP MOVLW 0xF8 ; 8 microsec overhead
CALL MICRO4 ; 248 * 4 + 2 = 994 here
NOP ; complete delay (ylp-"NOP")
NOP ;
DECFSZ CNTMSEC, f ; decrement count, skip when zero
GOTO MSECLOOP ; loop
RETURN
MSEC1 MOVLW 0xF9 ; 4 microsec overhead
NOP ; (2 for CALL) (ylp-"NOP")
MICRO4 ADDLW 0xFF ; subtract 1 from W
BTFSS STATUS, 2 ; skip when zero
GOTO MICRO4 ; loop
RETURN
BANKSEL PORTA
BSF PORTB,4
CLRF TXREG
;A/D initialsation (A/D not used)
BANKSEL ADCON1 ;Configure A/D Ports, left Justified
MOVLW B'00000100' ;RA0 = Analog input
MOVWF ADCON1 ;Rest as Digital I/O
BANKSEL ADCON0
MOVLW B'10000000' ;Fosc/32
MOVWF ADCON0
;Switch on A/D
BANKSEL ADCON0
BSF ADCON0,0 ;Sitch on A/D
CALL DELAY2
ATOD
BSF PORTB,0
BSF ADCON0,2 ;Start A/D conversion
ATODLOOP
BTFSC ADCON0,2 ;Check to see if conversion is finished
GOTO ATODLOOP ;NO
BANKSEL ADRES
MOVF ADRES,0
;Transmit data in WREG when the transmit register is empty.
TransmitSerial:
BTFSS PIR1,TXIF ;check if transmitter busy
GOTO $-1 ;wait until transmitter is not busy
MOVWF TXREG
RETURN
BTFSC W,7
BTFSC W,6
CALL DELAY1
CLRF TXREG
GOTO ATOD
end
this program has to do a transmission through uart communication between pic16f73 and eb500. it takes the signal analog from porta,0 , then does a conversion in digital and send it in tx uart.
kinds regards
title "PIC16F73"
CBLOCK 0x020
ENDC
GOTO Start
MOVWF DELAY1_VAL1 ;
MOVWF TMR0
MOVWF OPTION_REG ;
BANKSEL PORTA
LOOP1
MOVWF DELAY2_VAL1 ;
MOVWF TMR0
MOVWF OPTION_REG ;
BANKSEL PORTA
LOOP3
Start
CLRF PORTA ;
CLRF PORTB
;Port configuration
BANKSEL TRISA
MOVLW B'00000000'
MOVWF PORTC ;
MOVWF SPBRG
MOVWF TXSTA
MOVWF RCSTA
;Set the address
MOVWF PORTC ;
MSGTXT
RETLW d'1' ; 1
RETLW d'84' ; 84
RETLW 0x63 ; 'c'
RETLW 0x6F ; 'o'
RETLW 0x6E ; 'n'
RETLW 0x30 ; '0'
RETLW 0x30 ; '0'
RETLW 0x3A ; ':'
RETLW 0x30 ; '0'
RETLW 0x43 ; 'C'
RETLW 0x3A ; ':'
RETLW 0x38 ; '8'
RETLW 0x34 ; '4'
RETLW 0x3A ; ':'
RETLW 0x30 ; '0'
RETLW 0x30 ; '0'
RETLW 0x3A ; ':'
RETLW 0x30 ; '0'
RETLW 0x45 ; 'E'
RETLW 0x3A ; ':'
RETLW 0x44 ; 'D'
RETLW 0x34 ; '4'
CALL MICRO4
RETURN
NOP ;
RETURN
GOTO MICRO4 ; loop
RETURN
BANKSEL PORTA
BSF PORTB,4
CLRF TXREG
BANKSEL ADCON0
MOVWF ADCON0
;Switch on A/D
BANKSEL ADCON0
CALL DELAY2
ATOD
BSF PORTB,0
ATODLOOP
GOTO ATODLOOP ;NO
BANKSEL ADRES
MOVF ADRES,0
TransmitSerial:
MOVWF TXREG
RETURN
BTFSC W,7
BTFSC W,6
CALL DELAY1
CLRF TXREG
GOTO ATOD
end
kinds regards
